No compression in 2nd and 3rd cylinder
1989 GMC s15 automatic 4 cylinder ...
I found that there is very low compression in 2nd and 3rd cyl. like about 0 psi or 5 psi but 1st and 4th cyl. have 125 psi
is 125 psi ok or it is sill low?
also, truck was not running ...can it run on 2 cylinders?
and is there any other reason why it shows very low compression in 2nd and 3rd apart from either valves or lower engine problem?
Before I take it apart...I want to make sure nothing else is causing this?
