SH-AWD Is Pretty Cool - 2015 Acura TLX SH-AWD Long-Term Road Test
Edmunds.com
The 2015 Acura TLX is pretty sporty to drive thanks to its sophisticated all-wheel-drive system.
I said "most" of Acura's models are built on front wheel drive platforms, because the original NSX and current NSX are rear wheel drive. No correction is needed.
Acura chooses to equip its models with all season tires instead of summer performance tires (even the new NSX). Until a comparison can be made between a BMW and an Acura equipped with SH-AWD and similar horsepower on the exact same type of tires, I am not convinced that the BMW would be superior in handling. Let's level the playing field in terms of the tires and horsepower and then decide.
BMW is no longer the king of performance handling sedans. Most Caddies today can keep up with a BMW and the Caddy V series will have BMW (even the M) for lunch on a track. As for Acura, if they had the same shoes, as subatomic says, Acura may surprise you. The key to SH-AWD is to apply power in a turn so the system will work. If you lift then it will handle like any other front drive car.
