Rubbing/ Grinding Noise From New Rear Rotors
So recently I put new rear rotors on my 2005 Mitsubishi Eclipse. The rear right side has a very loud rhythmic grinding noise. I've gone through several forums, and many of them say to check if the shield thing is bent into it and its not. I can't really tell what is wrong with it.
When I turn the rotor while it is on the hub without the caliper and whatnot on, it turns freely until it hits a certain point where I have to use a bit more pressure to turn it.
Is there any other possibilities of what this could be?
