Removing oil pan
schuylerbschuylerb Member Posts: 2
edited December 2015 in Volvo
Put a hole in my oil pan and finally got the bolts off but power steering lines in way to finish removal. I was to.d by a volvo mechanic to lift engine a bit and it will help me clear way for removal but not sure how to do this. Any help greatly appreciated, thank you.
    I think the idea is to support the right side of the motor (passenger side) and drop the subframe just a little bit.
  • schuylerbschuylerb Member Posts: 2
    Do I need to do anything to the sub frame to allow that to happen? Thank you for responding!
    I really don't know enough about that particular car to advise you on which bolts to undo, sorry.
