Big noise (vibration)
amonrad1amonrad1 Member Posts: 2
edited December 2015 in Volvo
"I have a 2001 XC70 WAGON and is making big noise while moving, bigger the speed bigger the noise, engine in idle and in N (while in speed) the same. Could this be because of tires?
    Sure it could, especially if the tires have some miles on them and are "feathered" or "scalloped" (that's called "cupping"). It could also be wheel bearing noise or exhaust noise.
  • amonrad1amonrad1 Member Posts: 2
    Thank you! It makes sense. I'll check the bearings.
