Poor Key Fob Design - 2015 Ford F-150 Long-Term Road Test
Edmunds.com
This update to Edmunds' long-term 2015 Ford F-150 details the truck's key fob design, which just isn't very practical.
there's plenty of keyfobs with a panic button that don't press themselves. I've never had it happen to me.
The most obvious solution would be the ability to turn off panic response in the vehicle settings. I've never encountered that.
The next best solution is to disassemble the fob and disable the button. Either cram some sort of shim underneath the button so it can't be depressed all the way or else knock the micro switch off the PCB entirely.
On all of the Honda products I've owned you have to press and hold the panic button to sound the alarm. The panic button is also recessed and narrow so it takes a very deliberate push on the button to activate it.
