Codes p0700 and p0722
Now here is the scoop. Driving fine..then apply the brakes to slow down. Now the car will not go over 10 to 15 mph. My rpm is at 3500. Cvt tranny I pull over..turn the car off..wait a while. .then try it again...this time all is fine. I slow down..apply the brakes and make a left turn...car gets up to 60 mph. All is fine...I get close to home..I slow down..turn right..pull in..and back in trouble...10 to 15 mph..and d 3500 rpm and that's all the car will do?...code reads p0700 and p0722. But the inter web is all over the place...but no real solutions...help?
Common Problems That Trigger the P0722 Code
Defective Output Speed Sensor
Defective Shift Solenoids
Defective Engine Coolant Temperature Sensor
Defective Valve Body
Dirty transmission fluid that restricts the hydraulic passages
Defective Output Speed Sensor wiring or connector
