Drivers side rear running light not working, but turn/brake light do run.
Originally the i noticed the running light were on one morning and would not go off. Now the dirvers side rear running light is not working, but the turn/brake lights do work. I swapped bulbs from the other side, and it still does not work so they are not burnt out, checked fuses no problems found, any ideas? Oh, also the back light for the dash board is no longer working, not sure if its related but happened at same time.
