My 99 Tahoe is not firing.
done replace distributor coil ign module pcm what is can some one help
I have replace distributor coil ign module an pcm an it still has no spark help please
Answers
If that's okay, have you checked the ECM fuse?
If the fuse is good, put a test light on it while you crank the engine. If the light goes OUT when cranking, you probably have a bad ignition switch.
