Are you a current or recent car shopper who bought an EV and then installed solar – or who had solar already, making the decision to go electric easier?
OR
Are you a recent EV buyer (past 3 months) as a result of manufacturer incentives and dealer discounts on these vehicles, including year-end deals? Were you convinced to buy an EV after finding a good end-of-year deal, or due to uncertainty around which EVs will no longer qualify for full/partial EV tax credits in 2024? A national business reporter is interested in speaking with you. Please reach out to [email protected] by 12/15 if interested in sharing your story.
OR
Clever Coolant Temp Gauge, But What About Oil? - 2016 Mazda MX-5 Miata Convertible Long-Term Test
Clever Coolant Temp Gauge, But What About Oil? - 2016 Mazda MX-5 Miata Convertible Long-Term Road Test
Edmunds.com's long-term 2016 Mazda MX-5 Miata has a clever coolant temperature gauge, but nothing for oil temperature or pressure.
I'm not a [non-permissible content removed] moron. I know that the coolant is cold when I first start the car. What possible benefit is there to this particular system?
It performs the function of a modern idiot gauge while being cheaper to manufacture.
I think an oil pressure alarm would be more useful than an oil temp gauge on a Miata.
If you attach a code reader device like an Ultragauge (it looks like a small GPS device) that can give real time temp readings you can watch the temp fluctuate by 10-15 degrees while seeing little or no change in needle position.
And I like how BMW pioneered the variable redline on the tach when the engine is cold many years ago. Cold engines had a much lower redline and as it warmed up it moved to it's normal position. Better than the blue light.
It doesn't move when you have exceeded your recommended high setting. The computer will indicate a problem before coolant temp even reaches it's high setting. The computer knows that temperatures fluctuate just as you do and isn't concerned about normal fluctuations just like you. Modern systems monitor everything from coolant temperature to airflow coming through the radiator so they are able to alert you to a problem before it arises. For example new cooling systems determines what fan speed is needed by CFMs not just temperature or if the A/C is on or off. A bag blown into the condenser will cause the computer to request higher fan speeds even at lower temperatures because it senses reduced airflow through the radiator . If it's algorithms determine that the system is not responding as it should and/or there is not enough airflow coming through the radiator at the highest fan speed it will begin to move the gauge to hot. There is no overheating situation and the temperature is normal but there is a problem with the cooling system. Now the gauge is not at it's always 190 degree position but showing an actual 220 degree position. Still normal but it has your attention because it's at a position you never see it at. All because a garbage bag is blocking airflow to the radiator on a hot summer day. With a real time gauge you would never know that a bag is blocking your radiator because the 220 degree reading sitting in traffic on a hot day is perfectly normal.
