My car does this too. It's super annoying. If I'm using the correct key to unlock a door, why should my car think it's being stolen? Maybe I just didn't want the car to "Beep" outside my neighbors bedroom window at 1 a.m. from the key fob. Or maybe my key battery is just dead. If somebody happened to mug me and steel my keys in an attempt to steel the car, they wouldn't take the time to separate the key from the rest of my key chain and return everything else including the fob, even less of a concern for the Dodge, since they are one and the same.
The turn lock is mechanical and doesn't talk to the alarm system. The fob disables the alarm and then signals the power lock to actuate. Its possible to have the lock communicate when opened manually, but of course with added complexity and expense that would rarely be used.
On the Honda, Acura and Nissan vehicles I've owned unlocking with the key manually disarmed the security system. Cars had factory security systems that armed and disarmed with the key long before there were remote key fobs.
If I remember correctly, once you realize the key is dead you can manually lock the doors with the key. Then when you manually unlock with the key the alarm won't go off.
That's not much better. Once you're in the car, you would typically lock it by hitting the power lock button on the arm rest as you open the door to get out.
You know, I've had a couple of cars with antitheft alarms and neither of them would get confused if you locked the door with the fob and then unlocked it with the key, or with a different key. Seems like a pretty stupid thing to make the car do.
