Starting problems
worstcar05worstcar05 Member Posts: 1
edited March 2016 in Chrysler
Over the past 5 years I have had so many issue with the car. I would not command I have replaced the timing belt the transmission 1500.00 the alternator 150.00 fuel pump and dropping tank 350.00 head gasket coils and sparks plugs 350.00 inner and outer tie rods 600.00 cv joints shocks 300.00 radiator 200.00 motor mounts give me a break over 5 times costing 750.00 each time and the lists goes on the problem I have never been able to resolve is the starting issue sometime it starts no problem and other time have to start wait and do it a second time before it starts is feels like the battery alternator or starter is bad bad all has been replaced and check all the fuses lost
    You mean it cranks and cranks but doesn't start, or do you mean you start the key and nothing happens?
