Water Leaking Inside
Water is leaking into my Sienna van from the side curtain airbag emblem. I called Toyota and was told they've never encountered this issue. Just curious if anyone else has ever seen this.
Answers
If not, or if it leaks into the car, then you can take some aquarium tubing and stick in in the drain and BLOW.
Do NOT use a coat hanger and do NOT use compressed air from a large compressor. If you dislodge the drain hose inside the A pillar, then you have TWO problems.
