Electric fuel door latch and antenna
holycow5holycow5 Member Posts: 2
edited May 2016 in Mitsubishi
Any ideas on why electric fuel door latch and antenna do not work on 98 Mitsubishi Diamonte
Answers
    I don't have the fuse box diagram for that car but if you do, you might check to see if both those components run off the same fuse. That would be my first (obvious) guess.
    If not that, then some wiring glitch comes to mind. The two things could also be co-incidental and not related at all.
  • holycow5holycow5 Member Posts: 2
    Is there access to a wiring diagram for this car here. There is no fuse designations for these items in the owners manual
    edited May 2016
    Try bbbind.com. They have wiring diagrams for your ride. Looks like G-44 for the antenna but I'm not much good at reading schematics.
