Calling Los Angeles-based car shoppers: Have you recently traded in (or plan to trade in) a car with negative equity (i.e. the amount you owe on your auto loan is greater than the car's value)? A reporter would like to speak with you; please reach out to PR@Edmunds.com by 11/6 for details.
1998 Ford Expedition starts and then dies. It will not idle. Any help with this issue.
ddalethddaleth Member Posts: 1
edited May 2016 in Ford
Answers
  • prowler_mq5qm_prowler_mq5qm_ Member Posts: 12
    I remember seeing something on Youtube related to this. It was a Ford, but not an Expedition. Anyway, the video was about a faulty exhaust temperature sensor preventing the engine from idling. Do a search on Youtube for "Ford won't idle" and see what you get.
    Basic approach would be to make a quick check for serious vacuum leaks, such as a loose hose off the power brake booster---then do a scan and see if anything turns up as a stored trouble code.
    Will it stay running if you step on the gas?
    Could be lots of things going on here, and methodical diagnosis is required. Could be idle air valve, fuel pressure issue, faulty coolant temp sensor---the list goes on.
  • alwaysfords2alwaysfords2 Member Posts: 339
    I'd look at the idle air control valve as mentioned above.
