First Fuel Economy Update - 2016 Toyota Prius Long-Term Road Test
edited June 2016 in Toyota
Edmunds.com updates the fuel economy on its long-term 2016 Toyota Prius. It's getting 48.6 mpg so far.
    Lifetime average with many more miles logged should be solidly in the 51-52 range, especially if there's a lot of low velocity city driving being done.
  • banhughbanhugh Member Posts: 315
    Probably they fudged the numbers. It's difficult to fill out the cars log at the gas station while wearing a paper bag with two holes to see through in order to avoid the embarrassment of being seen in the new Prius.
  • dougnutsdougnuts Member Posts: 26
    Range is what determines time between fill-ups, not MPG. At 380 miles per tank, you'll still be visiting gas stations quite a bit, which is unfortunate.
  • mfennellmfennell Member Posts: 91
    380 is the farthest they've driven between fills. Tank is a bit bigger than 11 gallons so range is about 550 miles.
