Electrical problems
Had red lights flashing, tac needle dropping to zero, speedometer dropping to zero, engine quit and all return in sec. Repeats continually. Went to shop and all the same answers, can't find a thing wrong. Read in forum by someone to change the ignition switch. Suggested this to auto repair and didn't want to touch it because their diagnostics says it's ok. Went to "You Tube" and found exact problem I was experiencing. Solution was to check connextortion to ignition switch for loose wires or grounding on metal. If not that, change the ignition switch. I ended up changing the ignition switch myself and the car has not repeated the problem so far.
