1999 Chevy Venture
I have a 99 Chevy venture that runs great when cold. When it reaches normal operating temperature it dies. When you try to restart it it spits and sputters backfiring through exhaust and engine. If you let it cool down it will restart and run until reachile normal temp then repeats the sputtering and backfiring. Where should I start?
On your own with a pro scan tool, about the only logical thing you can do is see if you can borrow or rent a fuel pressure gauge and see if fuel pressure is dropping over time.
