2004 Mercury Monterey/ Ford Freestar Transmission On going Issues (Engine 4.2)
If you get this code P0732...your are at a minimum replacing the soft components of your transmission. Recommend replace all soft components if you have the work done....
TRANSAXLE NO 1-2 UPSHIFT AND DTC P0732
TECHNICAL SERVICE BULLETIN
Reference Number(s): 04-17-10, Date of Issue: September 6, 2004
FORD: 2004-2005 Freestar
MERCURY: 2004-2005 Monterey
Superceded Bulletin(s): 04-15-12, Date of Issue: August 9, 2004
4F50N TRANSAXLE NO 1-2 UPSHIFT AND DTC P0732
ISSUE
NOTE: This article supersedes TSB 04-15-12 to update the vehicle model years.
Some 2004-2005 Freestar/Monterey vehicles, may exhibit a diagnostic trouble code (DTC) P0732 and a no 1-2 upshift condition. This may be due to an intermediate clutch piston seal becoming torn or loose (de-bonded) from the piston.
ACTION
To service, perform normal diagnosis per Workshop Manual. If the cause is determined to be internal to the transaxle, inspect the intermediate clutch piston seal. The outer clutch seal is bonded to the piston. If the seal is torn or loose replace the piston. Inspect the intermediate clutch plates and replace if necessary.
ISSUE
ACTION
