ABS system
jedd33448jedd33448 Member Posts: 1
edited August 2016 in Suzuki
I have removed the 2 abs fuses from my fuse box under the hood but my warning lights are still showing on the dash. I thought if they were removed this would not occur. Any advise?
    Generally pulling the ABS fuse causes the light to go on, not go off. You might be able to shut the ABS light off using a scan tool (with the fuses back in) but if you don't correct the fault, the light will come back on.
    You might have dirty wheel sensors, so that's worth checking.
  • BillySeterBillySeter Member Posts: 2
    what if your code reader says noy supported
