Infinity Stereo / Radio
I have a 2009 Hyundai Sanata Fe Limited. Every now and then I get a loud noise from the stereo, it's almost a bang like a firecracker but lasts longer. I thought it might have been electrical interference like lightning or power tranformers. It's happened with the radio, the USB port and playing a CD. On one occassion the unit ceased working and didn't come back till several attempts later. The noise is much louder than the listening volume and I must saw quiet alarming. I was wondering if anyone else has experienced this?
Not much I can say about an actual cause, but I would pull the unit and check for a bad ground, first of all. If examining the wiring doesn't reveal anything, then it would have to be bench tested at an audio shop. It might be an amplifier problem. Sometimes it is cheaper to just buy a replacement unit from someplace like Crutchfield (www.crutchfield.com). You might not only pay the same as you would to repair your old unit, you may actually get a better system.
