95 S10 with awful miss
storm_rstorm_r Member Posts: 1
edited October 2016 in Chevrolet
I have A 95 S10 four cylinder 2.2 it has a really bad miss. It doesn't miss him first or second but between third and fifth it starts messing like crazy I can barely, Little hill I have to put it in 1st or 2nd to make it. The more I push the gas the worse it gets. It completely loses all power, my rpm's drop completely. I've changed my plugs, plug wires, cool pack., air filter and fuel filter. My fuses all check out fine. I've cleaned my injecters, cleaned out My intake, Does anybody know what else it could be?
    edited October 2016
    You need to do some actual testing, or have it done. Otherwise you're working in the dark.
    I would try to pull some trouble codes. Your car is a transition year for diagnostics so you'll have to find out which system you have. You might need to consult with a mechanic to figure that out, and have him look at what type of diagnostic port is on your truck.
    You should also do a fuel pressure test.
