Here are the symptoms, can you please help?
She's an '05. I'm having problems starting her. She doesn't always want to turn over. Occassionally at first, then more and more frequently. And I'd have to let her sit longer before I could start her again. Almost seemed like she wasn't getting fuel or out of gas but the tank was full. Before taking her to a shop, I could replace the fuel pump/filter for a bit of coin. Any suggestions? Thanks in advance.
Sure you could start guessing and throwing parts at it, but that's an expensive hobby.
You can buy a spark tester quite cheaply, and perhaps you can scrounge a fuel pressure tester? Applying those two things when the no-start occurs might give you some answers.
Intermittent no-starts can be tricky to solve. You need to have the test gear in place when it's happening.
