-September 2024 Special Lease Deals-
Ford 500 Traction Control Light
amhak907amhak907 Member Posts: 1
edited November 2016 in Ford
I took my Ford 500 in to the Ford dealership to have all 4 brake pads replaced and the rear rotors. I received a voicemail from one of the mechanics stating that they were having trouble replacing the rear right rotor - apparently he was having a rough time compressing the caliper. When I went to pick it up the next day, the traction control light wouldn't turn off. I called and let them know and they said to bring it in. On my work order/invoice from the replacement it states "during test drive traction control light came on. Unable to determine cause. Refer to service." I was never referred to service when I picked up my car but when I called in the next day they told me to come in. They have had my car for 4 weeks now and after my latest phone call they are telling me that it is just a freak coincidence that my light is on after being recently serviced and that it will cost me around $500 to have the sensors replaced. Is that really the case? Could they have accidentally damaged the sensors when they did the brake pad and rotor replacement?
    No way to know unless you first know the code being read and which type of sensor is being indicated. If it's a wheel sensor, the harness could be damaged during a brake job; if it's related to a differential sensor, then highly unlikely. Also sensors and or tone rings are sensitive to road damage or dirt; also tone rings can be contaminated from brake dust from the pads.
