Power draining.
I have a 2009 Hyundai Elantra. I recently started having a problem with my battery dying. I've changed it and it will start right up. After I drive it for awhile the battery is dead. I've pulled the positive off to test the alternator while running. Checked it with a volt meter. Said it was charging. Hooked the meter up to the negative post and negative cable and I'm getting almost a 4 amp draw from somewhere. I went thru and pulled every fuse while the meter was hooked up to find the draw and the meter never dropped. What else could be pulling my power??
First off, don't ever do that! Potentially harmful to the alternator and perhaps other electronic components on a modern car.
Now, to your question. It seems likely that you missed a fuse. Most modern cars have more than one fuse box, so you might want to consult your owner's manual. Usually there's a box in the engine bay and one in the passenger compartment, often on the left kickpad or under the dash around the steering post.
Here's a good VIDEO on CHECKING PARASITIC DRAW
Here's a simple TUTORIAL on how to test an alternator with a DVOM (if that's all you have available).
