2005 Odyssey Transmission Problem
I just had the rebuilt transmission replaced as the old one started slipping.
The new one is also causing some trouble--although I don't feel it as the transmission seems to be working fine. From time to time, I get a check transmission indicator on with a flashing D4 indicator. When I turn off the engine and restart, the errors disappear. But then the flashing D4 and check transmission error will appear again, either soon after driving or sometime later--and doesn't matter whether I'm easing out of a stop or accelerating up onto a hill. But, there is no vibration or jerky gear shifts.
Anyone has had a similar issue or might suggest a fix?
