2006 Lincoln Towncar - Strange noises
baili1315baili1315 Member Posts: 1
edited January 2017 in Lincoln
Car is making loud humming noise. Used to only hear the noise when I turned the car off. Now I hear it when I start the car and frequently while driving.
  • Does your chime come on when you put the key in the ignition? With the engine on, have you raised the hood to determine if you are hearing a noise from the engine?
  • Poking around a bit online... could be related to the Idle Air Control valve or a vacuum leak. Those seem most likely given questions people are asking about "towncar humming noises".
