2015 CR-V intermittent unresponsive driver control
Sporadically, the driver's control will not raise one of the rear windows on my 2015 CR-V. Absolutely no response. It will subsequently clear some minutes later and function normally again, raising and lowering the window as if nothing was wrong. Problem only occurs every few weeks. Dealer cannot reproduce the problem.
Anyone have a similar problem?
Best Answer
[Deleted User]
Hmm... electrical gremlins are tricky for sure. I feel good that we're on the same page (flip the switch to clean it up a bit) If nothing is physically loose, could be a cracked wire? Something that flexes with opening and closing of doors or vibrations of driving and temporarily breaks a power connection until it shakes back into place? I suppose it's also possible (and perhaps makes slightly more sense) that it's a symptom of an impending issue with a window regulator.
I guess documenting the "events" is the best thing to do at this point. Maybe a pattern will emerge, or something will finally fail and reveal itself.
Let's hear it for the EE's! That's my degree as well
5
Answers
Can you correlate the times it doesn't function with any kind of event? In and out of the car a lot with multiple door open/closings? Certain types of weather?
The dealer is also stumped. He trouble shot and found no loose or dirty connections. He can't fix something when it isn't broken when he sees it
Nat
At least this is a non-critical situation... unless the failure happens while the window is down with impending weather!
