Why is my Subaru vibrating?
greenagate99
Member Posts: 40
Okay, my car has been doing this for a while now, but recently it seems like it has gotten worse (now also vibrates in drive). I recorded a brief video of it, in which you can hear the vibrating but can't really see the steering wheel and outside mirror vibrating. My car has around 96,500 miles on it (1999 Subaru Impreza Outback Sport).
https://www.youtube.com/watch?v=GCq_05jD3_M&feature=youtu.be
Any ideas? Is it the motor mounts?
https://www.youtube.com/watch?v=GCq_05jD3_M&feature=youtu.be Any ideas? Is it the motor mounts?
For rough running at idle, there could be many other reasons---when was the last tune-up? Also a vacuum leak could mess up the air/fuel mixture and cause a rough idle. And yes, motor mounts, but chances are you'd notice that while you were driving or shifting from drive to reverse. You could also have a part of the exhaust system touching the body and vibrating that way.
It needs to be looked at.
Last tune up? I'm not sure. Oil was changed a couple months ago, and that's about it. The CV joint/boot was replaced either last year or the year before. Can this wait a few months or is this something that should be taken care of now? I can get a new(er used car) once I get a job after college.
As long the vibration isn't severe, and you don't hear any unusual noises while driving, and if the car's performance hasn't suddenly dropped off, then you can probably let it go for a while, sure.
My only concern about letting it go is that if there's a misfire in the engine, or low compression, eventually that's going to turn on your Check Engine Light...if you see that go on, then you should take it in.
I think the spark plugs were replaced four years ago, if I remember correctly. I remember one of my uncles pointing that out to me.
