1996 Dakota - No Spark from Coil
My 1996 Dodge Dakota was running fine when one day I could not get it to start. I changed ignition coil, plugs and wires and switched the ignition relay with same relays in fuse box. It turns over fine, but no spark. Do you have other things to check regarding getting a spark out of the new coil?
The CPS is in the distributor, looks like a flat plate.
This may help you to test it:
http://easyautodiagnostics.com/misc-index/ckp-cmp-sensor-basics-1
