2002 Pathfinder - CODE P1145
My 2002 Pathfinder is throwing code P1145. Changer the valve assembly dealer part# 23796-4W01C, cleared the code but it still shows the code but it came back on again. Anyone had this problem. if so please advise if you solved it
Primary cause is low or dirty oil
Other causes:
Faulty IVTC sensor, or IVTC circuit open or shorted
Bad terminal connections in this circuit
Faulty Crankshaft Position Sensor
Faulty Camshaft Position Sensor
