Need advice on Radio
2012 Jeep Grand Cherokee standard radio where the AM and FM will not work. The SiriusXM function does work. So there is sound. Yes, the AM/FM/SiriusXM is all in one on the same radio. Switching from SiriusXM to either AM/FM stations the radio does visually display the stations and I can switch the AM/FM stations and the visual display actually shows stations changing. However, there is no sound from any AM/FM station. Switching back to SiruisXM there is sound. All fuses are ok and I have reset the entire car by unplugging the battery for 15 minutes. Going crazy... I have googled this issue and cannot find a solution... please help.
That's about all I can think of, given your symptoms, other than having the unit bench-tested once it's out.
