2006 Santa Fe AC only blows hot air, compressor never comes on
AC blows hot air, freon ck and is good no leaks, plenty of pressure, found the diode was blown. This happened immediately after I had a new battery installed, replaced diode, still hot air, diode blown again. Went back to place I bought battery and the new battery was shorted out.......got new battery, new diode, still hot air......diode blown again. Could the shorted out battery have messed up something else that would keep the compressor from coming on?
Best Answer
thecardoc3
Member Posts: 5,878
You don't have to go to the dealer to find a technician who is capable of solving this, but it does sound like you need someone with more skill than who you have been going to. Search the member directory of the iATN for someone near you.
https://iatn.net/repair5
Answers
Was the original battery dead and the car needed to be jumped to get it started? Were the cables accidently connected backwards? Was the battery accidently connected backwards when it was installed? Suspecting a "shorted battery" and trying to diagnose from there is a mistake. Forget everything you know about the car and test and prove what it is doing right now. Connect a scan tool and recover codes from all of the modules in the car. List them.
Does the PCM data show that the AC is being requested to be turned on?
Does PCM data show that the clutch is being commanded on?
Does data in the PCM or HVAC modules display AC system pressures? If so what are they?
