2010 Subaru Impreza base model with abs and traction control light coming on.
smileymac13smileymac13 Member Posts: 2
edited July 2017 in Subaru
Quick question, I have a base model 2010 Subaru Impreza. While driving at random the abs and traction control lights will both illuminate. I also can't turn on cruise control while this happens. Restarting the car makes the problem go away but it comes back again later. I checked my fuses and brake fluid level and they are fine. I am planning on taking it in to the dealership but am hoping for knowledgeable suggestions of what the gremlin could be so I can plan accordingly.
  • smileymac13smileymac13 Member Posts: 2
    Whelp, thanks for the great advice.
  • thecardoc3thecardoc3 Member Posts: 5,878
    Nobody would just know what is going on. Someone has to start by pulling codes from all of the modules on the car and then begin to analyze the situation. ABS and traction lights suggest an ABS system issue and any codes in the ABS system would be assigned the highest priority in the diagnostic routine.
    Did anyone retrieve system codes and can you post them?
