2010 Forester check engine light , skid light , cruise light blinking
took car for inspection last week , was told that the head gasget was leaking . got it back yesterday , paying almost 3 grand . today check engine light & skid control light on , the cruise control light blinking . its at the dealers again . they are supposed to be good cars with great mechanics . any advice please ?
There is also the problem where a failure results in the computer blocking tests from running that should detect other problems. When tests are blocked, the trouble codes that they could generate don't get created to give the repairer any indication that something additional is wrong. Then as maybe in this case after the head gaskets are replaced, now the computer can run all (or at least more) of its tests to completion and it now detects issues and turns the light on, which really means it is doing exactly what it is supposed to do.
Of course there is always the chance that some type of an error occurred during the repair and now the computer has detected and generated a code for it. This could be the result of a technicians mistake or simply a component that while it appeared to tolerate servicing has in fact failed as a result of it. It happens. All you can do at this point is get the car back in and have them investigate the situation. It might be a simple fix. Post the code(s) that are retrieved and then we can have a better idea of what is going on.
