-September 2024 Special Lease Deals-
ABS module 2009 Sportage
johndeer2johndeer2 Member Posts: 1
edited October 2017 in Kia
When reconnecting the brake lines to the ABS module they thread in easily until
just before they seat, at which point they feel like they are cross threaded and
refuse to seat. There is no dirt or crud in the female threads but I did find one small thin shaving in one with a Qtip. Any suggestions for what caused the problem, although I'm leery of trying to force them to seat I did try to tighten one until instinct told me it was enough? I know they did not seat because when I filled the brake reservoir, I could not get rid of the air when I bled them and then I noticed fluid seeping around the fittings on the ABS module.
One line that was not disconnected appears to sit at a slight angle to the module,
do some of the lines thread in at an angle and if so is there a picture or schematic
available that shows the direction they angle or do they all thread in straight?
Any suggestions are welcome. Thank you
Answers
    sounds like maybe they were crossthreaded before you got to them, but without leaking. sometimes one does not find out about crossthreading until the lugnut/connector is removed and attempted to be replaced. sorry no specific/easy answer other than find same car in junkyard and look at it? (i love junkyards and try to work them into every answer here on edmunds, just so you know.)
