Ford Taurus strange radio problem
ejost398ejost398 Member Posts: 1
edited November 2017 in Ford
Radio memory shows power on both sides of the fuse block and battery is drained very quickly. help please
Answers
  • radio head unit appears failed and seems consistent with the root cause of the battery drain. you can probably verify this by running car without radio for a while, after putting a full/proper charge on the battery with a trickle charger. then maybe swap in a junkyard radio from taurus or get one of those subwoofer booming systems that vibrate an entire city block.
