How can i fix the leak?
palfaro92palfaro92 Member Posts: 1
edited November 2017 in Dodge
I just noticed today once i parked my van i saw a leak and it was the antifreeze, the leak coming from the passanger side but not leaking from the radiator. How can i fix the leak if ot easy or not, or where the leak may come from?.
Answers
  • Front or rear of engine?
    Front could be a hose, water pump or thermostat cover.
    Rear could be heater hose, heater core or worse, head gasket.
    The first thing is determining exactly where it is leaking.
    There are UV leak detection flashlights at auto parts stores or on Amazon.
    Most green antifreeze will glow brightly with the UV flashlights or you can get an antifreeze leak detection dye to really make it glow.
    Once you have determined exactly where the leak is, then you can determine what to do about it.
    Sorry, but until we know exactly where the leak is, we probably aren't going to be much other help.
