Problems with my VW Passat
petermurrrpetermurrr Member Posts: 1
edited December 2017 in Volkswagen
Hello! Something happened with my Volkswagen. The engine began to run unevenly, appeared to vibrate, and the oil consumption increased. Has anyone encountered this problem? What is the reason?
  • This happened suddenly, or over time? Since you mention oil consumption, it sounds like an ongoing thing? How much oil is it using? Do you have any kind of smoke coming from the exhaust? The more details you can add, the more folks here will be able to try and help
    Yes more details would be helpful, because with the symptoms you describe, the list of causes can be as long as your arm.
    Have you pulled any trouble codes?
    When was your last tune-up?
    How much oil is it consuming, say per 1,000 miles?
