Nissan Pathfinder Tire Pressure Monitor
I owned an infiniti G20, beautiful car; had almost 100,000 miles and never had a problem. I was searching for a car for my son at a nissan dealership, saw the new pathfinder, my husband really liked it. Got it (leased); 39months lease. About month and a half ago or so, I got the tire low pressure light came on. I asked my husband to check it out. When he took out to drive that day, light went off but he still had the tires checked to make sure that the air is where it should be. Now all of a sudden the light is on again yet my husband said my tires are ok from a pressure stand point. I am frustrated because this is a nuisance. I don't have the time to take it to the dealership everytime. Please help!! car only has 8,010 miles on it.
You're far more likely to get a reply if you post your message in one of the existing forums such as the main Nissan Pathfinder Owners: Problems & Solutions or Nissan Pathfinder discussions.
Good luck!
Note that another vehicle with tire pressure monitors like yours parked next to your vehicle can interfere with the system and trigger the light. It should go out shortly after you move the vehicle.
"Good quality" tire pressure gauges are discussed in this forum under "Tire Pressure Gauges" - accugauge was one mentioned (a digital gauge - easier to read than the traditional rod type).
Note also, tire pressure monitors were mandated by US Congress - it was not a "bad idea" by Nissan. It was a result of the Firestone/Ford exploder tire problem episode.
We had the same problem on our 05 Pathfinder LE 4x2. It was a bad valve/sensor on the tire.
We discovered this after every week checking pressure and filling up air and trips to tire shop where they could not find a flat.
Dealership found the problem and fixed it under warranty.
Hope this helps,
Frank
Check 'em when they're cold, not after they're warm - 35 PSI, as measured by a quality, reliable tire gauge.
Can anybody advice me what to do ?
