2011 Sonata - oil consumption
2011 Sonata with too high oil consumption. Have under 82K miles. Delaer has done 4 oil consumption test.
They want to do 2 more. What next?
Answers
http://www.hyundai-forums.com/yf-2011-sonata-i45/
do you know about the engine failure problems with the YF Sonata (2011-2014)?
Oil level is critical!
i check my oil weekly and keep it near/a bit ABOVE the "F" mark
Did you have the engine recall (#132) test done?
The main thing right now is, should you get this repaired you need to service the engine with a product approved for GM's dexos specification, and not just something labeled synthetic or synthetic blend and especially not something that only meets the API and ILSAC specifications.
