engine failure
purchased a 2004 Durango new, currently 98,000 miles, performed good maintenance, loved the vehicle; December 2017 started it and immediately had a knocking sound. I took to 3 mechanics, received same analysis - bent connecting rod. Estimate to replace engine $7000. research on-line - numerous failures of this type cause valve seat drops out and into cylinder or build up of fuel in cylinder and upon startup over stresses connecting rod. very disappointed, from forum I'm not alone. My loyalty to dodge is now zero. any hope of a recall or compensation for their poor design and our loss?
End of vehicle life issues are always sort of tricky to sort out. Do you get nickle and dimed to death as things deteriorate? Does a big issue like this make the decision for you?
Keep us posted on how things progress
Did anyone take the cylinder head off to confirm? Otherwise, it's all just speculation as to what occurred.
It doesn't sound like the vehicle is worth repairing, and at 14 years, there's little hope of factory compensation--so I'd say you just have to write it off and move on.
Just bad luck and old age, would be my opinion.
The only other thing I could suggest which might make sense is a good used engine. If the vehicle is in good shape, this might make financial sense. But putting $7,000 or more into a $4,000--$5,000 vehicle would be a tough decision to make.
