rough idle, jerking motion
jlmiller1990jlmiller1990 Member Posts: 1
edited April 2018 in Chevrolet
Having a similar problem like others, when sitting at a stop sign my 2011 Chevy equinox starts a rough jerking motion back and forth. It also have a rough idle when in park. But there is no check engine light on.does anyone know what would cause this. Dealership can't seem to duplicate issue.
Answers
  • turrrrboturrrrbo Member Posts: 4
    Sounds like the clutch might be slipping, either or your break pads are extremely worn. Rough idle is likely caused by spark plugs or ignition coils, however those won't be enough to cause the car to shake back and forth. How many miles are you at on the car?
  • SaltysubohmSaltysubohm Member Posts: 1
    My 2012 equinox just started doing the same thing can you tell me what the problem is?
  • thecardoc3thecardoc3 Member Posts: 5,858
    Sorry, but it doesn't work like that. Each vehicle needs to be diagnosed to prove what is causing a given problem. Is the check engine light on or flashing? Has anyone checked for codes? Under what conditions is the symptom occurring?
