Turn Signal Issues
lbarnes8318lbarnes8318 Member Posts: 1
edited May 2018 in GMC
the passenger turn signal starting flashing real fast so I bought a new bulb, put in and the signal was still flashing fast. The fuse is OK. any thoughts..lbarnes
  • Typically the bulb replacement will do the trick. Could be the turn signal flasher perhaps?
  • rickdonrickdon Member Posts: 123
    Usually, a bad bulb or ground issue can cause rapid blinking.
