2000 toyota avalon 3.0 lier engine noise cold for 1st 10 mins like powersttering empty
David Robinson Sr.David Robinson Sr. Member Posts: 1
edited August 2018 in Toyota
i had technician install gates timing belt kit with waterpump at 109,000. about 1000 mile later loud su\queeling noise heard on cold starup for almost 10 minutes.i think something got bent on disassembly. took back to shop now they tell me oil pump noisy. runs fine no lights,no knocking from engine.i tbeginning to think this guy blowing smoke.any ideas. i changed timing belt because car was running fine and good shape wanted to keep it awhile.
Answers
  • 0patience0patience Member Posts: 1,712
    Lots of questions come to mind.
    What kind of belt did he use? OEM or aftermarket?
    Some cheap aftermarket belts make quite a bit of noise.
    Which is why it is best to use an OEM belt.
    The other thing is, did he replace the water pump when he did the timing belt??
    If not, then it is quite possible the timing belt is slipping on the water pump and causing the noise or the tension was set incorrectly.
    When ever a timing belt is replaced on an engine that the timing belt drives the water pump, the water pump, thermostat and radiator cap should be replaced. There may be some argument to that, but it's cheap insurance to have to avoid tearing it all apart again.
