ignition coil replacement
I'm wondering if i have any recourse to the dealer on recent repairs.
I have 126,500miles on this Impreza Outback Sport. 5,000 miles ago on dealer's recommendation , I replaced head gasket, plugs and wires, when doing the timing belt. Now, check engine light came on and code indicated replacement of cylinder 3 wire. Compression test is good. They recommended replacement of ignition coil and plugs and wires which I have not done. Mileage is dropping dramatically now after a few days of driving (to 18 from 25).
Am I risking more damage by not replacing coil?
Should the dealer have seen this problem when replacing head gasket or during multi point inspection at 121,574 miles?
Should I have to pay for plugs and wires again?
Bit out of my depth here. Thanks for any insights.
One way to tell is to switch wires with another plug and then clear the code. If the CEL comes back on and shows a different cylinder misfire, you know it's the wire you switched.
