O/D off light flashing in Mazda MPV 2003
i have a mazda mpv 2003, the gear had been jerking at 2RPM since purchase as a used imported vehicle, but it started showing O/D off light flashing some days ago , and the transmission is behaving funny, experiencing slowdown at 2& 3 RPM along the jerking which is more pronounced now , even after changing the fluid. Codes PO328 and POO31 HO2S, but a car electrician inspected it thoroughly and said one fuse in the valve body of the transaxle is bad saying its better to get a new transaxle.What do u advise?
Answers
Perhaps a different type of scan tool will be required to access the TCM or PCM.
It sounds like you also have a bad knock sensor, possibly a bad 02 sensor (probably not, though), some wiring issues, or maybe even a bad PCM.
This problem requires expert and methodical diagnosis. It's hard to know if you have engine or transmission problems here.
