Parasitic power drain
BackyarderBackyarder Member Posts: 1
edited September 2018 in Dodge
I've recently developed a power drain coming from my power door lock circuit in my 97 dodge Dakota. Disconnected the switches, but still have the drain. If I pull the fuse it stops but then I have issues with the factory alarm.
Answers
    Pulling the fuse isn't the best way to do this. You can easily get fooled by various modules turning on and off. You might want to check out a YouTube video on doing a voltage drop test for each fuse, using a simple multi-meter that measures millivolts.
    You should also have a wiring diagram so you know what's on that circuit for that fuse and what's not on it.
    Tracking down parasitic draws can be tedious. You might try a "wiggle test" at the harness leaving the fuse box to see if that changes any readings.
