Transmission leak
jetblackjetblack Member Posts: 3
edited October 2018 in Chevrolet
My transmission is leaking oil. I changed the oil cooler line fitting on the transmission on the driver side of the transmission but can not locate the other fitting. The transmission is dripping oil when I start the car it leaks like it is under pressure it is not just seeping. I was told there is another line on top of the transmission but all I can find is a breather hose. I am laying on my back with the transmission 6" from my face.
  • jetblackjetblack Member Posts: 3
    This post is from crank grinder
    You should get the car on a lift so that you can see what's going on, perhaps with the car running. The problem with leaks is that they often blow-back while driving, making the source difficult to find. If you spread some newspaper under the car, that might give you some general idea of location, and where to look when you lift the car.
