ELECTRICAL TROUBLESHOOTING
BIASHARABIASHARA Member Posts: 1
edited October 2018 in Ford
Hi Everyone,
I hope all is well with y'all.
My 95 Aerostar with over 250K miles has been making me scratch my head. I recently had the shifter cable replaced after the gear lever stopped engaging.
Soon afterwards,
~Turn signal/multi-switch doesn't work though the flash/hazard lights work,
~Radio and A/C doesn't work
~Reverse lights don't work
I have checked the fuses and all are intact, so are the bulbs on the said lights.
I cleaned grounds( Found one attached to vehicle body under hood and other one by engine block.)
I also had the ignition switch and cylinder replaced but the issue still persists.
Any leads/info to getting this corrected will be highly appreciated.
